CV Joint question
Shoman594
Moderator
Lockport, IL
Hey guys, How do you get the cv joint out of the intermediate shaft connection ?
Thanks!!!
Shoaz
Studly dood
Scottsdale, AZ
The same way as getting it out of the tranny; give it a good yank, or use a pry tool to pop it out. It's easiest to remove if the intermediate shaft is still bolted to something solid (like the motor mount). ;)
There's a c-clip in there that can make it stubborn, so it needs a bit of an impulse to pop it loose sometimes.
Shoman594
Moderator
Lockport, IL
No wonder why I am having problems!! hahah :)
Thanks for the info.
DemonNeno
SHOCAGO Freak
Skokie, IL
Yeah, that c-clip can be a pain in the ****!! I like the bearing that retains the passenger side axle, it makes it tons easier to remove... And haven't heard of them going bad for anything i've read.
