cv half shaft replacement
bmray21
Ft. Wayne, IN
how hard is it to replace the halfshafts? it doesnt sound too bad, and considering they are only $65 at autozone i figured i might as well get rid of the annoying noise they are making. can i just pull them out of the diff, or do i need any special tools? any help would be greatly apperciated.
thank you
bryan
jthomas68
Area 51
No special tools needed.Id recommend getting under the car a day ahead of time and spray everything with PB Blaster.It`s a pretty simple swap,but if the bolts are rusty,it cna make the job alot harder.We had to burn of about half of my bolts,and even the front endlinks.Thr drivers side will leak tranny fluid when you pull it,so just be aware.
