Custom sub box/amp rack
SHO_OFF_95
Green ATX SHO
IL
it took me two weekends but it is now finished
my idea was to build a full system for under $500, and i didL c59433f23289f5593c1f2971f9dc6d4f
L 9ecc2a1318e4e3527281cf800656879f
tell me what you think Fyi the subs are 12's
whiteman_01
Well-Known Member
Hastings, MN
Looks good. I have been wanting to have a box made of fiberglass to fit in the rear corner of the trunk, right behind the wheel well.
30footSHO
In da mountains
Boise, ID
Can't really tell how well everything fits from those photos. Definitely went with the low-budget components, though. Wonder what that Crunch amp really puts down at 14.4V... 'cause I don't buy that 1000W RMS rating. How's it sound?
SHO_OFF_95
Green ATX SHO
IL
due to lack of a good camera :banghd: the pics arn't to good
but for the money i paid for it the setup is awsome for under $300
for the amp and subs, i used some carpet padding cut down some of the rattle in the 1/4 pannels. ya but after i EQ'd everything on the amp it self it sounds great, and i renderd the rear veiw mirror useless:rockon:
Venom SHO s7
Washington
it looks like a nice install.
actually, the amp says 1000watts MAX not rms, and the model number being 250.2, im gonna assume they'll try claiming 500watts
Mechanicsville MD
I used to be an installer and have been doin custom stereos for a while now fiberglass and all that. If im not mistakin that amp looks like a 2 channel 1000 watt. What that means is its putting 500 watts to each speaker. If you want to get a little more sound out of it do this very simple thing. On the amp itself switch the positive wires and leave the gound wires where they are. Itll be bridged then and 1000 watts will be goin to both speakers. There might be a button on the amp too that says "bridge" press it when your done.
250.2 tho....hmm. Do what i explained, you will be surprised
SHO_OFF_95
Green ATX SHO
IL
will that blow thw subs they are only 500watt each
Sexymeatball
MA
Max and RMS are too hugely different things. Max cannot be trusted. Espeically in lower budget amps. Too much depends on current draw and efficiency. In addition, the resistence plays a key role in output. By halfing the resistence, you are effectively doubling the output, but it starts from a baseline. Look carefully at the specs. Its best to match RMS to RMS for the amp and sub application. Nice amps can have an RMS as high as half of the Max. Cheap ones as low as 1/4.
30footSHO
In da mountains
Boise, ID
I got the RMS rating from some websites where those amps are sold. That is why I was skeptical.
