Cruise control
SuperHO
Mental Patient
St. Joe, MI
The cruise on my 92 ain't working all that great.....actually, it doesn't work at all. when I have the cable hooked up (which I normally don't), it drops speed slowly until I tap the gas pedal and it runs back up to speed again, before bleeding off again. Another interesting thing is that when I idle with the cable hooked up, it idles around 3400rpms.....I have to floor the gas momentarily and it drops back down....until the next time I come to an idle. Do I need a new cruise unit or what?
SHOblime
State College, PA
Does the cable move freely throughout it's travel? Sounds like it might be getting stuck/hung up on a sticky part or something?
SuperHO
Mental Patient
St. Joe, MI
newp....in fact, when I hook it up, I've gotta pull on it pretty hard to get it to release from whatever it's snagged on inside the cruise thingy.
SuperHO
Mental Patient
St. Joe, MI
wow...never knew the cruise was so involved....
any idea, ball-park figure, of what it might cost to replace my damn cruise in my 92 MTX?
Rockledge
Pluggin' away
Connecticut
Same thought I had.
In addition, it sounds like maybe a vacuum leak could be causing the cruise to "fade" as you describe and might even be contributing to the high idle when the cruise is engaged. Have you checked all the hoses?
SuperHO
Mental Patient
St. Joe, MI
Yup. Had the intake off two weeks ago because of a gold-mine find (6 brand new Motorcraft spark plug wires at the boneyard $.59 apiece). All the vaccuum lines are hooked up gutentight. The high idle is caused by the cruise cable holding the throttle open.
JoesSHO
Reality
Plug wires
So **- are you the one that took the intake and wires off the black SHO at U-Wrench-It? :naughty:
SuperHO
Mental Patient
St. Joe, MI
:dig: Actually, I just took the wires...brand new Motorcraft ones...never fired.....$0.59 each. I didn't take the intake though.
I did, however, rape the 'puter and DIS module off the black 93......:evilgrin:
