Crank Scraper anybody?
Ian Macoomb
Ottawa, Ontario, Canada
I was searching e-bay the other day for stuff for my beater ('91 Pontiac Firefly aka a Geo Metro). Anyway, I came across a crank scraper. No I didn't buy it but the theory sounds interesting. I may just try it next spring and find out how much it really helps.
Anybody ever considered this? Discuss.
Ian Macoomb
Funny, I thought Paul knew every little trick in the book to increase horsepower.
I'll post an excerpt from the e-bay add since I can't post a link to it:
"This is an inexpensive and simple way to add power to your Suzuki G13A and G13B motors!
This is an oil- or crank-scraper for the various SOHC and DOHC 1298cc and 1324cc G13 engines used in many Geo and Suzuki models (there is a very slight difference in stroke between these two displacement engines which amounts to a net difference of only .75mm or about .030” at the scraper and this is allowed for in the design). The scraper is constructed from 12 gauge mild steel (approximately .10” or 2.5mm thick). Installation instructions are included. Some minor clearancing might be required.
The scraper includes a set of 5 longer main bearing cap bolts which allows it to act both as an oil scavenger and a light duty main bearing girdle. The existing main bearing girdle as used on the G13B is retained but is not required to fit the scraper (some of these engines do not use a main bearing girdle as seen on the G13B). A picture of the installed oil scraper is shown.
Many sincere thanks to Suzuki enthusiasts David Gray and John Strattons without whose help this scraper would not be available!
As the engine rotates, engine oil is not thrown off but instead sucked into a tornadic windage cloud around the crank and rods: the horsepower that is required to move and move through that oil is significant. The scraper strips away that cloud by coming close to – but not touching – the spinning crank and connecting rods and this frees up that internally consumed horsepower. Remember that as you accelerate, brake, go up and down hills, and turn your vehicle even more oil is whipped up and power lost; stock engine output is determined from a static test so the scraper will help restore that lost power ASAP! In highly tuned engines, too much oil splashed on the cylinder walls can overwhelm the piston rings and thereby be introduced to the air/fuel charge. This contamination will lower the effective octane rating of the fuel and can lead to detonation. This is well-proven technology that has been used with great success in small and large displacement high-performance street and racing engines for decades. In fact, we just completed an updated scraper design for a 1965 Pontiac 389 -- this is an OEM engine that utilized a crank scraper in the form of louvers cut into the side of its windage tray -- that's 38 years ago folks.
You can find more information on crank-scrapers if you follow the link found in the “ME” eBay icon.
Each scraper is made to order so please allow ten business days for fabrication from the date that payment is received. That being said, we now have a CNC cutter which has allowed us to ship most orders within a day or two. "
ricky
sharpsburg,nc
it looks like a variation on the old windage tray used years ago to add a few hp to motors. by reducing oil spash, crank would spin easier, less frothing of oil. modern oils have greatly reduced the benefits, thinner oils [guys used to run 50w on some tracks][remember your dad using straight 30w or40w] and less froth from high detergent oil. dry sump oiling systems also did this but with the added benefit of more ground clearance and better oil pressure. IMO would probably add about 1 to 2 hp at the risk of insufficent oil flow.
Westerly, RI
Crank scrapers have been around for a while. It's a lot different than a windage tray though. The idea is to scrape all the oil off the crank, so as not to fling it around the oil pan/lower end. It's a popular addition to a normal performance engine rebuild nowadays. Many companies make them for the "Big Three" V8's.
The basic shape is cut out in the metal, but for final installation you'll need to install it, check the clearance, and grind to fit.
I read in a Car Craft magazine that a small block Chevy could gain up to 10 HP by adding one of these. Not bad for the investment, IMO, and you have the added safety of more oil being available in the pan.
