Markus
I'm about to change my waterpump. I need to buy a crank pulley puller. What is the best type to get? What types should I avoid? How do I minimize damage to pulley, crank bolt, crank threads?
Thats what I did tooautobahnsho:
The kit I used was missing some longer bolts, so I ended up using the bolts that hold the timing belt covers on....
Is that an approved SHO procedure?![]()
Yeah and make SURE you torque down that bolt when you put it back on. Crank cancer is not fun, believe me.rangerj:
Before you put it back together clean the crankshaft end and the inside of the pulley, and then apply a light coat of grease (silicone grease or wheel bearing grease). This will help to prevent "crank cancer".
