cps
DEMONICSHO
94' atx
portland oregon
okay ill try asking this again, no codes, bogging down, bucking, hesatation, anyway i think it may me a cps starting to go out, i know the cam sensor has to do with tach reading but i also read that the crank sensor does as well, my question is if you unplug the cam sensor after it gets to temp. should you or should you not have a working tachometer? also where exactly id the baro sensor located on the 3.2? any help would be much appreciated.
Mr Anonymous
Tire Wall
Sounds like a contaminated or failed MAF to me. Try cleaning it and reset the PCM and see what happens.
It's not the CPS. When the crankshaft position sensor faults, the engine gets NO spark. None. Nada. Dead. A faulting CID sensor can cause stumbling and ugly starts, but it will set a memory code. Without codes, I would suspect the secondary ignition system: plugs and wires.
