cps replacement
raven
cleveland, ohio
since my sho is still dead, and i think it needs a fuel pump, so i am just going to upgrade it to the 155lph. also, i hear i should replace the crank position sensor and the water pump.
where and how do you replace the cps and the water pump??
thanks
oh yeah: i have a 92 5 speed with 95k miles
AutoXSHO
Glenwood, MD USA
The crank position sensor is located behind the front timing covers of the motor. A good portion of the front of the motor has to be disassembled to get at the CPS and the water pump. You should consider picking up Mark Nunnally's 60k video, which discusses this in detail.
In addition visit shotimes.com, which has a good writeup of the 60k CPS replacement.
I have to tackle this same thing to replace the crank sprocket for the timing belt.
John V
95 MTX with mods.
