Cooling fan not coming on
93_SHO_off
Kingston,MI
I have a 93 atx, the cooling fan is not kicking on at all. I want to check to see if its a fuse but I don't know which one it is. I don't have an owners manual. thanks for any help.
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
Your ECT is most likely bad. If the computer can turn the fans on during the KOEO self test, but not under normal driving, it doesn't know its getting hot. The ECT is probably bad. Is your fuel economy poor as well? Does the fan turn on if you turn the A/C on?
93_SHO_off
Kingston,MI
The fans aren't kicking on with the a/c on. But the fuel economy might be a little off. the last time I checked it was like 20, but that was with the fans working correctly.
Rob94
Northbridge MA
Yup, it's the ECT sensor. Replace it. Make sure you get one with a BRASS probe, not a plastic one. The plastic ones are junk and will last a few thousand miles at best.
SonicRiot
Handbanana!
CT
Check your relays for the fan as well... there are more than one. Also...when the A/C is on, is it actually working? Is the compressor kicking in?
The ECT is the Engine Coolant Temperature sensor, located under the throttle body. It sends info to the computer to tell the car to go into open or closed fuel loops and tell the fan to kick on when the car gets to a certain temp. Just do a search and you will find a wealth of info.
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
93_SHO_off
Kingston,MI
no, my a/c doesn't work. but if it were a relay would the fans still come on with th koeo test? btw,thanks for the pic autosho. I will check the relays and probly change the ect anyway. Thans for the help.
Axianator
I am a banana!
Roanoke, TX
I'm with Chris (AutoSHO) on this one. If the fan kicks on during the KOEO test but won't activate while you're driving, then the relays are most likely fine and not to blame. I'd change your ECT sensor first and then see what happens afterwards.
30shopower
New Hampshire
i have Changed my ECT with a Brand New Ford sensor and the fan will still not kick on in my 92 3.0 SHO it did come on when i hooked up the snap on scan tool the fan will not come on with A/C on i have had it on N O in NORMAL still no fan will come on :cry: :frown:
30shopower
New Hampshire
Yes the fan came on when i hooked the snap on scan tool up i forgot to put than in i went back and added that in.
JMoff92
Rochester, NH
I agree, it is most likely the ECT. I had the same problem last year, my fan would never come on, even when I turned on the AC. (never tried the KOEO test.) But I replaced my ECT and still no fan.
Then I replaced the ICRM (it contains the relay for the fan.) After that it worked perfectly. But since your fan turns on during the test, the relay is probably good.
Slo-Sho
It wasn't me!
Crossroads, CNY
In your earlier posts...
116 (O,R) Engine Coolant (ECT) sensor out of range - ECT
Did you replace the correct sending unit? The two-wire and not the single wire for the dash gauge? Can you provide us with a part # from the part invoice?
SHOtimer
#2910
Santa Clarita, Ca
That wasn't him, that post was a year ago and a different member.
Doug
hondas hate me
97Cobra
Greeley
Ccrm
mine did the same thing and it was the CCRM wich i dont know what it stads for but its right under the fan shroud cover. up by the drivers side headlight :thumb:
