shnerby
I Was wonderring what kind of coolant to put in to my 91 sho
I concur .... the green stuff. Supertech from Walmart is as good as any. Or Peak. Or Prestone. Buy the 50/50 premix, or buy the full strength and use distilled water to dilute it.
w/e you get make sure yes its the green stuff but more importantly is compatible with cast iron and aluminum, some coolant isnt supposed to be used with aluminum and can cause problemsOh and FWIW buying the 50/50 mix is about twice the price as buying the stuff you dilute yourself
dont you just boil water and then let it sit to make distilled water??? i recall hearing something like this.
i also worked at a jiffy **** (ontario, canada here) and we just mixed with tap water... same for the flushing machine. guys from head office came down to check everything out, and do a bit of training. and never mentioned it at all.
i just used tap water in my grand am (mixed 50/50 with coolant of course)
honestly, making an absolute 50% to 50% mixture is not of much concern... are you gonna take the mix to a lab and get it checked out??? close is close. they have antifreeze range tester just for that reason!
You can buy distilled water for less than $.60 per gallon.
That makes a $9.99 gallon of Preston (AutoZone/Advance) into two gallons of 50/50 mix for $10.57 . . . . and total cost at ChinaMart is about $9.45 for a gallon of Preston and distilled water. You cannot get two gallons of 50/50 pre-mix for anywhere near that.
It wouldn't me either.I would not be surprised if the factory used tap water
Avoid Super Tech - many of their products (including their oil) are RECYCLED!
