coolant temperature sensor
zerg1024
NJ
hey i was wondering where the coolant temperature sensor is located so i can change it.
Ishodu
The one for the gauge is located just in front of the thermostat. Follow the upper rad hose back to where it connects to the thermostat housing(1 wire sender). The temp sender for the ECC is located on the lower portion of the water outlet tube. Directly below the firewall side of the throttle body(2 wire sensor).
zerg1024
NJ
the one for the eec where is that located i need to change it bad.
SASHO91
Zoom Zoom
San Antonio,TX
if you look down behind the TB, it is kind wedged between the rear head, and the thermostat housing...
