The one for the gauge is located just in front of the thermostat. Follow the upper rad hose back to where it connects to the thermostat housing(1 wire sender). The temp sender for the ECC is located on the lower portion of the water outlet tube. Directly below the firewall side of the throttle body(2 wire sensor).
