Coolant problem:coolant light on
SHONJ622
New Jersey
my coolant light keeps coming on. Every once in awile my clamp comes off the upper radiator hose and it leaks out there so then i get why my light comes on. Now it just seems to come on. Could this be an electrical problem? I changed the t stat even though the other one wasnt bad. I bled the radiator somewhat but i should prolly do it again. What could this problem be?
Mr Anonymous
Tire Wall
The coolant light comes on to indicate a low coolant level. Is your reservior filled to the proper level? You may need to try cleaning the contacts on the coolant level sensor.
SHONJ622
New Jersey
i think i already cleaned that sensor. Its a metal like thing at the end of the dipstick i believe..if so i cleaned it..if not...tell me where it is
stevetatro
Cincinnati, Ohio
If you cleaned the gunk off the sensor, and there's not a bunch of gunk at the bottom of the reservoir, and you have the proper amount of coolant, and your light still comes on, the sensor is bad.
Yes, you got the right sensor.
Good luck.
SHONJ622
New Jersey
if this sensor is bad. what do i ask for and can i get it at Autozone..if so..whats the part #..and how much do you think it will cost?
Get rid of the clamp that is allowing the hose to come off.
FIREMT1977
