rangerj
Just as a suggestion. When mixing fresh anti- freeze (coolant) use deionized distilled water instead of tap water. The minerals in tap water, such as lime, calcium, iron, etc are what accumulates on the inside of the radiator and elsewhere in you cooling system.
Mix a gallon of anti-freeze with a gallon of deionized water for a 50/50 mix. After flushing the system blow out as much of the water used to flush the system with LOW air pressure (no more than 20 PSI). The coolant should be changed anually (once a year). Static electricity builds up in the anti-freeze and this is what deteriates the hoses from the inside.
A simple but inexpensive part that is often overlooked is the radiator cap. The cap puts pressure on the system, which raises the boiling point of the fluid. With engines designed to run at higher temperatures, this is even more important. Puting in a 180 degree thermostat is NOT a viable option. At a minimum the thermostat and radiator cap should be changer every three years. The fan(s) and temperature sensor are equally important.
With the fall season approaching, and winterizing that comes with cooler weather, this may be a good time to discuss this. This may also be a good time to discuss this given the number of forum participants that are haveing their systems running higher temperatures than usual.
SDPATT, AV8TOR, and all others, please add your suggestions and comments. The more experiences shared the better. What about additives, such as water pump ****? Where are the common leaks, and how to detect them, or better yet prevent them. Preventative maintenence tips (cooling system or otherwise)!
In the postings I see a series of common problems. Are there any suggestion out there on how we can address the problems, such as a list of common problems, diagnostics, and repair procedures. Is this kind of thing buried in the archives somewhere? This forum is a great thing. Can we improve it? rangerj
