coolant leak
raphy rod
las vegas
hello.i have 95 3.2 atx.I have been smelling coolant lately in the car while driving.Then when i lift the hood,i smell it also.There is no puddles or obvious leaks.I've thoroughly inspected everything.The only evidence of a leak is there is some green fluid underneath the bottom of the a/c compressor right around where the a/c hose connects to the compressor.Also at the bottom bracket of the front compressor where one bolt holds the compressor on.I don't wan't any worse problems in the future,so any help to find this leak would be appreciated.There is no leaks from the peep hole on the pump.
SASHO91
Zoom Zoom
San Antonio,TX
there is another weep hole on the pump... its at the 8 o'clock position, or so...
another place that it might be leaking from is the pick up tube gasket.
either way, a new water pump is always a good PM item...
the part number for the pump and gasket set is somewhere here on the forum... a search should turn it up...
raphy rod
las vegas
hello.thanks for the quick reply.Where is the pick up tube gasket?I'm not familiar with that term.thanks
