hello.i have 95 3.2 atx.I have been smelling coolant lately in the car while driving.Then when i lift the hood,i smell it also.There is no puddles or obvious leaks.I've thoroughly inspected everything.The only evidence of a leak is there is some green fluid underneath the bottom of the a/c compressor right around where the a/c hose connects to the compressor.Also at the bottom bracket of the front compressor where one bolt holds the compressor on.I don't wan't any worse problems in the future,so any help to find this leak would be appreciated.There is no leaks from the peep hole on the pump.
