Constant misfire and oil on plug.
CCXVI
On the way home the car lost power and barely made it up the driveway. Got misfire codes, including cylinder 1. Swapped coils and it stayed, pulled plug and it looked good but has oil on it. No strong gas smell, but it could still be the injector. Are plug seals a common failure, and could it leak enough to cause a misfire?
Did you clean the area and put a new plug in? Yes oil can foul spark plugs if that is the question. Not to be one to just throw parts at things, but a repacement plug is cheap and easy to take care of. If that cures the misfire then replace seals and you should be good to go.
CCXVI
Yeah, cleaned the plug and it still acted up. Still need to swap the plug with a good one just in case, but this is the 12 hour nights weekend so its waiting until a day off
You are sure the misfire didn't move from one cylinder to another? Hard to be sure without a code for which cylinder has misfire
CCXVI
It gives you a code for which cylinder is misfiring. It was still cylinder 1.
Valve cover gaskets commonly fail on Bank 1 on Gen 5 SHOs. Usually cylinder 3 but hey LOL.
CCXVI
Alright, I'm gonna pull a few more plugs and take a look at them and then see if moving that plug moves the issue.
CCXVI
Spark side. Insulator side was clean.
Not 100% sure about the newer motors but usually leaky vc/ spark tube gaskets leak up top. Is this different on this model?
krewat
Long Island
No valve cover leak in the world is going to put oil on the combustion side of the plug unless it was on top and got on it when you pulled the plug. But then, the insulator side of the plug would be wet too.
You either have a bad turbo seal, or your PCV is sucking oil. Hopefully, the latter ;)
I was assuming oil on the plug threads, not on the electrode itself. If there is oil on the threads, the valve cover gasket is the likely culprit.
