2012 SHO 133,*** Miles.
It was running poorly so I changed all 6 injector as well as the waterpump due to a leak. I also changed all the coil packs and spark plugs. I marked the timing chain and used locks on the camshafts while replacing the waterpump. I put the car back together and now it won't start. It has fuel pressure at the rail. It will crank and not start. I tested all the harnesses to the injectors as well as the injectors themselves and they are good. I can't tell if it has spark.
The tachometer doesn't seem move while the car is cranking. I'm absolutely lost. Any help would be appreciated.
