Black-taurus
I have a problem with my 90 shos AC. the compressor froze on me.I put a small belt around just the alt+crank but the belt still brushes up on the comprssor. does anyon know how to pull the compressor it looks like theres two 14m bolts attaching it from the bottom are there any others besides this two i was having problems I couldn't even get one of tose loose there both so hard to get at its a real problem. does anyone have any tricks to get at them? i was using a wrench ad getting about 1 degree turn at a time . also there was a bracket or something under the two bolts i thought i could loosen up the bolts were easier to get at. i loosened a 14m and a 15m nut to see if that could make the compressor pivot out of the way it didn't . what is that bracket or whatever? is it just for the compressor should I put the bolt back?
Thanks guys
Thanks guys
