Complete List of TSBs
way2evil
ny
This is a list of all the current TSBs which I have stored on my server. Feel free to download whichever you need.
11-08-21
6F50/6F55 TRANSMISSION—SLUGGISH ACCELERATION FROM 0-8 KM\H (0-5 MPH) FOLLOWED BY A HARSH BUMP OR A SLIP ON TAKE-OFF FOLLOWED BY A BUMP—BUILT ON OR BEFORE 4/15/2011
11-5-6
*6F50/6F55 TRANSMISSION - SLUGGISH ACCELERATION FROM 0-8 KM\H (0-5 MPH) FOLLOWED BY A HARSH BUMP OR A SLIP ON TAKE-OFF FOLLOWED BY A BUMP - BUILT ON OR BEFORE 4/15/2011
11-5-3
*3.5L GTDI ENGINE RUNS ROUGH, HESITATES, SHUDDERING WITH MISFIRE DTCS P0316, P0301, P0302, P0303, P0304, P0305, P0306
11-4-20
*6F50/6F55 TRANSMISSION AWD - FLUID LEAK - BETWEEN PTU ASSEMBLY AND TRANSMISSION CASE
11-3-19
* BLIND SPOT INFORMATION SYSTEM (BLIS) AND CROSS TRAFFIC ALERT (CTA) - FALSE BLOCKAGE AND/OR DIAGNOSTIC TROUBLE CODE(DTC) - U3000
10-22-4 Added 1/2/10
BLIND SPOT INFORMATION SYSTEM(BLIS) AND CROSS TRAFFIC ALERT(CTA)—FALSE BLOCKAGE AND/OR DIAGNOSTIC TROUBLE CODE(DTC)—U3000
10-22-4
* AWD VEHICLES - SHUDDER/CHATTER/VIBRATION ON TURNS OR THUMP/CLUNK NOISE ON LIGHT ACCELERATION - BUILT 10/1/2009 TO 12/31/2009
10-21-6
* DTC P2111 OR P2112, OR LOWER THAN DESIRED ENGINE IDLE SPEED, ENGINE IDLE SPEED FLUCTUATES WITH OR WITHOUT DTCS
10-21-2
* 6F50/6F55 TRANSMISSION - SLIP/NEUTRAL OUT, 5TH GEAR START FROM STOP, ELECTRONIC PRNDL ERROR, BACKUP CAMERA IN D - BUILT 3/13/2009-6/30/2010
10-20-11
* SIRIUS RADIO WITH NAVIGATION - UPDATE PROCESS FAILURE - BUILT ON OR BEFORE 3/8/2010
10-20-8
* TIP-IN DELAYED SHIFT AT SPEEDS BETWEEN 15-20 MPH (24-32 KM/H)
10-20-6
* BLIND SPOT INFORMATION SYSTEM (BLIS) AND CROSS TRAFFIC ALERT (CTA) - FALSE DTC B11D6:15 WITH INTERMITTENT FAULTS - BUILT ON OR BEFORE 5/21/2010.
10-18-7
* SPEEDOMETER INDICATOR NEEDLE STICKING OR INACCURATE - BUILT ON OR BEFORE 3/25/2010
10-17-10
* 3.5L GTDI - RUNS ROUGH, HESITATES, WITH MISFIRE DTCS P0316, P0301, P0302, P0303, P0304, P0305, P0306
10-17-3
* FRONT BRAKES - INTERMITTENT GRUNT OR GRINDING NOISE
10-15-2
* CENTER HIGH MOUNT STOPLAMP REPAIR/REPLACEMENT PROCEDURE
10-14-2
* PTU FLUID LEAK - VENT AREA
10-13-4
* SYNC NON-NAVIGATION - NO TURN-BY-TURN DIRECTIONS AND/OR UNABLE TO PIN POINT VEHICLE LOCATION - BUILT ON OR BEFORE 6/14/2010
10-13-3
* FM RADIO RECEPTION/SOUND QUALITY CHANGES WHILE DRIVING OR SATELLITE RADIO SIGNAL BLEED THROUGH WHEN USING AUDIO SYSTEM IN AUX MODE
10-9-9
* 6F50/6F55 TRANSMISSION - DTC P0751 - HARSH OR NO FORWARD ENGAGEMENTS - PERCEIVED SLIP ON ACCELERATION - SLIP/DELAYED AND/OR HARSH DOWNSHIFTS
10-8-3
* SYNC - CALL SOUND QUALITY/BACKGROUND NOISE ISSUES AND/OR VOICE RECOGNITION DIFFICULTIES WHILE DRIVING
10-8-1
* ADAPTIVE CRUISE CONTROL (ACC) - TURNS OFF
10-7-2
* REAR BRAKE DRAG OR REAR BRAKE NOISE - BUILT ON OR BEFORE 12/14/2009
10-6-4
* 6F55 TRANSMISSION WITH ECO BOOST (GTDI)- BUMP 3-1 COASTING DOWNSHIFT BELOW 10 MPH (16 KM/H) BUILT ON OR BEFORE 3/1/2010
10-6-2
* REAR PACKAGE TRAY/SPEAKER RATTLE/BUZZ WITH THE RADIO ON - BUILT ON OR BEFORE 12/9/2009
10-6-1
* POWER STEERING FLUID LEAK AT THE RESERVOIR FILL CAP
10-5-12
* INTELLIGENT ACCESS KEY WITH NO KEY DETECTED OR NO FOB DETECTED - BUILT ON OR BEFORE 3/11/2010
10-5-9
* LUGGAGE COMPARTMENT LID SOLENOID STUCK OPEN
10-4-3
* 6F50/6F55 TRANSMISSION - SHIFT FLARE INITIAL 2-3 SHIFT / SLIGHT DELAY/BUMP 3-1 COASTING DOWNSHIFT BELOW 10 MPH (16 KM/H) BUILT ON OR BEFORE 11/17/2009
10-2-8
* SYNC SYSTEM DEFAULTS TO OR STAYS IN PRIVACY MODE, MULTIPLE VEHICLE LINES
10-2-6
* AFTERMARKET POWERTRAIN CONTROL MODULE CALIBRATION, NON-FACTORY MODIFICATION OR AFTERMARKET COMPONENTS
09-25-7
* SERVICE TIP - POWER TRANSFER UNIT (PTU) - RIGHT HAND INTERMEDIATE SHAFT SEAL LEAKS
09-24-13
* RAIN SENSOR MOUNTING RING DETACHED FROM WINDSHIELD
09-23-9
* 6F50/6F55 TRANSMISSION AWD - FLUID LEAK - BETWEEN PTU ASSEMBLY AND TRANSMISSION CASE
09-23-8
* DTC P0096-INTAKE AIR TEMPERATURE: IAT SENSOR 2 CIRCUIT/RANGE PERFORMANCE - BANK 1 - BUILT ON OR BEFORE 10/14/2009
09-23-2
* RADIO - HIGH PITCH WHISTLE OR WHINE NOISE BUILT ON OR BEFORE 9/24/2009
09-19-2
* POOR AM / FM RADIO RECEPTION WITH REAR DEFROST ON
Crax
Nevada
My god thank you and I mean it! I just saw this and tomorrow I am going back for a 2nd look, they failed to fix my rear sunshade rattle and BLIS issue first time around. It will be most helpful to have these with me to discuss!
zeus268
Maple Leaf SHO
Edmonton, Alberta
I was just thinking the other day how great it would be to have a list like this and now here it is! Thank you so much! This is the kind of thing that you only find in a great forum.... :thankyou:
mjhpadi
Pennsylvania
Echoing what others have said, thank you, thank you! These TSB's are very helpful. Found 2 that have affected my car, nothing serious but will be nice to get corrected while the car is in next time for 10-17-3. Way2Evil, it was awesome of you to share these. Thanks again.
way2evil
ny
dont know if any of you would need it but i have the ability to check for any open recalls on all fords if anyone needs me to check feel free to send me a pm
Are there any recalls on the 2010/11 SHO?
Unknown_Driver
V6TwinTurboAWD
Ontario Suburbs
holy shit thank you!
edit just adding a bulb list thanks to BPD
High & low beam headlamp
HID-D3S
Parking light
3457A
LED
Front turn signal
3457A
Rear turn signal
992 (7440A)
Tail light
3057
916
Stop light
3057
High mount stop light
LED
License plate
168
Back up light
7440
Front sidemarker
168
Rear sidemarker
916
Map light
2825
Dome light
2825
64111
1BlueBull
SHO Lover
Virginia
This made my dealer give me the deer in the headlights! Can't thank you enough!
Andella
Massachusetts
Just had my car serviced for TSB 11-08-21. The service invoice says they performed TSB 11-09-11. Anyone see this yet? Not sure how it varies from 11-8-21.
cheech
Pa
Same procedure they just added a seperator plate to the parts list. The old TSB only wanted you to replace one now they have you replace both.
No difference in the repair I guess some gaskets were getting damaged during removal so now they want both changed.
Heathcotejosh37
