Compatibility between Gen 1 & 2 Core Support?
93redATX
SHOForum O.G.
WI
The '90 needs a new upper core support, and I've seen one place (Hollander interchange manual) that says the core supports can be interchanged between Gen I and Gen II Taurus/Sable. I'm thinking this is incorrect, but I'd like a firm answer from someone else. From what I could see on the busted-up front end of the '90, the core supports look similiar in size/shape/etc. to that of a second gen shrug
The '90 struck a deer, which completely destroyed the upper core support, but the upper rails are straight, along with the subframe mounting points. It was a somewhat strange hit, as the deer landed dead center (right on the grill) and stayed right there. It didn't roll off the car, fly to the side, or anything of the sort.
93redATX
SHOForum O.G.
WI
philallemang:
I will look personally for you tommarow.......I will even post some pics. I just got done taking an 3.2 ATX engine out so thats no problem.
Thanks Phil. You da man thumb
<small>[ February 22, 2004, 11:16 PM: Message edited by: 93redATX ]</small>
RStalveyARFF
too many shos
Georgetown, MA
radiator support? Totally interchangable between Gen I and II. It's the same frame, just different sheet metal.
