cold plugs
justin mccluske
washington
does any one know if by putting in 3923 (one step colder) rob hourse power off the bottle because my car seems slower . they are double platnem autolights
AREA 91
PA SHO SHOP
Area 91
Colder plugs will give you less power off the bottle.
Platinum @ N2O are a no no.
1slickRED89
Guest
Toledo Ohio
I'm pretty sure the heat range change should not make a diffrence in power, as long as the firing location is the same, that is you maintain the stock .133" center electrode stickout, which is a "power tip".
the autolite APP has a higher voltage requirement than a copper core or a finewire, so if you igntion wires and other parts are marginal it could misfire a little and reduce power slightly.
try reducing gap to .035" and clean and dielectric grease the wires. also consider running autolite racing 3923 or autolite XP 3923.
justin mccluske
washington
ok,thanx guys! i didnt know that double platnems are a no no , what kind of plugs exactly should i be running with a 55 shot of zex ? and as for my ignition,my plug wires are the 8mm talors and i also have the msd dis-4 retarding it by 1 deg at 4000 rpm's because for what ever reason my car likes it. posibly thats caused by all the go fast crap on my car
AREA 91
PA SHO SHOP
Area 91
Autolite 3923
The're 1 step colder, and cost a buck each.
