codes wont clear
SIREDZO
BOSTON MA
i keep getting 1 1 1 and that means system ok but it wont clear help. i tryed to do the procedure to clear but it wont work.
If you are running the KOEO test with a 1991 SHO and there are no codes set, you should be seeing the following sequence (you are looking for 2-digit codes, not 111):
flicker - fast codes, disregard
Hard Faults - found during test
flash - 1 in the 10s digit
2 second pause
flash - 1 in the 1s digit (that makes an 11)
4 second pause, will repeat the hard faults
2 second pause
flash - 1 in the 1s digit (that makes another 11)
6 second pause
flash - separator pulse
6 second pause
Memory codes - stored if CE light has illuminated
2 second pause
4 second pause, will repeat the memory codes
2 second pause
For a graphical description of what you are looking for, go here.
