Marccus
Battery indicator light on panel came on. Battery ok. Alternator is putting out 18.5 volts. Had to drive 40 round trip miles to get new alternator, battery is hot as an oven. Battery vented acid into engine compartment.
Installed new alternator. Output is 14.5 volts. Check battery under load. Battery is ok. Very difficult starting, won't turn over, rough start. Runs for a while, then stalls. Ran KOEO test. Codes 11, 11 then 19 & 95. Codes 11, 11 means sensors ok? Right?? So codes 19 & 95 are in memory...right?
Code 19 indicates PCM is gone, code 95 indicates fuel pump problems, but ran fuel pump self test and fuel pump ok. But car should run ok because codes 11, 11 indicate that sensors are ok. I'm confused???
So, did high voltage output of 18.5 volts fry PCM? Also, ran KOEO many times, kept getting different codes each time until last three times got codes 19 & 95 consistantly. Also, finally tach has been running erradically, now no tach.
Please advise
Please advise
