AHLEV8R
I would appreciate some help with deciphering these codes. What needs to be done?
First off my '94 MTX with 80K (30K since engine rebuild) every once in a while - but now just about every time I drive it - It feels like a cylinder (or 2) drops off line - Check Engine Light comes on - RPM drops a couple hundred. This lasts from 5 sec to 5 minute. If I shut if off and wait 5 minutes it starts right up and runs fine (for a while) except some times the Tach is working right away.
157: is MAF sensor below min voltage - I replaced the MAF sensor
which did not make any difference.
214: is Cylinder ID Circuit Malfunction - guy at the parts place said there is a chamber in the exhaust after the CAT that send a signal to the computer - I don't have a chamber after the CAT! Can't find any wires on the exhaust!
542: is Fuel pump Secondary circuit open - Ground - does this mean I need to clean the ground contact for the fuel pump?
Thanks !
Tokico struts, Eibach springs, Grizzly clutch kit, Ultra lite flywheel, HiFlow air box, SVT underdrive pulleys w/belt, Spiral cv halfshaft boot kit, a Borla SS with cats, Pro-M Bullet 75mm MAF
Thanks !
