blackcurrant
While cruising down the road in my 94 MTX with 99k miles my car behaved as if it was running out of gas. The tach continued to measured speed. i feathered the throttle and it ran a little further at certain throttle positions before it finally wouldn't go any further. i drifted off the road. i restarted the car and it fired right up....drove a little farther and it started'running out of gas' again. keeping the throttle at a certain position...around 1/4 throttle...kept the engine running but as i headed into town that became impossible. i coasted off the road and restarted and drove...each time the car running less and less until finally it wouldn't start. i'm ashamed to admit whether i remember the fuel pump priming or not. called AAA and had it towed home. once it was off the hook she fired right up...pulled into garage and ran codes....
KOEO
121 TPS out of range
173 rear o2 sensor
528 voltage at pin 10 or 30 (AC was off!)
542 fuel pump open, bad ground or always on
KOER codes were normal
Grateful there were no 211s!!!
car starts and runs...i hear the fuel pump prime and run at startup.
went ahead and checked DIS connections...cleaned connection to manifold and ground connections which were corroded.
Finally..the question i have... where are the fuel pump connections and grounds?
Thanks
Mike
KOEO
173 rear o2 sensor
Thanks
Mike
