schwagman85
Alright ive got a 95 3.2, in janurary sometime i had to jump my car cuz my battery died yada yada. Ever since then my ABS light has been on constantly. As soon as you start the car its on, no flashing, no turning on after you reach 25 or try to use the ABS, its always on. So i pulled the codes from the ABS system and i got 22 which translates into Left Front Inlet Valve. So here is what i have done/replaced
Correct me if im wrong but i believe this is called the ABS Pump
The ABS Computer
And This relay
I have also checked all of the fuses. I have cleaned all of the connections with spray electronic contact cleaner. I am still getting the ABS light along with code 22. I am out of ideas here. Does anyone have any
for me???
The ABS Computer
And This relay
for me???
