Code 212
SHOCAN
Seattle, WA
A '93 ATX keeps storing code 212. Supposed to be the SPOUT. No other codes. No CE light. I've cleaned the SPOUT connectors with electronic cleaner, what else can I do? What should I be checking? Runs OK except for some preignition under load.
Markus
Ottawa, Ontario, Canada
SHOCAN:
My documentation indicates code 212 is "Loss of ignition diagnostic monitor input to powertrain control module or spark output circuit grounded"
Possible causes:
• Open harness circuit.
• Shorted harness circuit.
• Damaged Ignition Control Module (ICM).
• Damaged PCM.
You might want to try using a good ICM and/or PCM(EEC) to see if these fix the problem. If they don't then I suspect you have a wiring problem.
