code 211 other issues
HYoung
Wilmington NC
I recently bought a 94 SHO from friends. Mechanically the car has been rebuilt but he couldn't figure out the following problem/problems.
The car has very slow pick up through out gears. At times it would kick in
and run correctly. He could not pull any codes. I bought the car and we were able to pull code 211 which is erratic or missing ignition PIP signal.
The crank shaft position sensor. There are other issues that I would like to know
if they are related to this sensor or are problems of their own.
  1. When I had the oil changed it was hotter than normal
  2. The Temp on the car was running 3/4 up on gage when driven more than a short distance.
  3. At times the car starts fine. Others it is hard to start or will not kick in and idle or take gas to keep it running.
  4. The car temp headed toward hot in third gear when it would not kick in changing gears. I quickly stopped the car and just as I stopped it was hot enough to steam. I did not drive the car in the red at all.
  5. When checking the radiator and refilling (small amount) with water the radiator acted as though it were clogged or I was told a possible cracked head.
