Code 211 diagnostic?
St Louis SHO
Rollin' coal
0 .· ` ' / ·. 150
I've got about 500 codes, but the only one im concerned about at the moment is the 211.
Let me give a rundown of the symptoms:
Car randomly bucks/jerks (not a misfire, almost like you turned the key off/on)
Car randomly does not pull over 6k
Car randomly idles like shit; AF=lean
I swapped DIS modules, and coilpacks, and CMP sensor to no avail. I wanna say CKP, but I sure know from my experiences that they usually just die, or wont work sometimes.
Any ideas?
- James
It seems either the crank sensor has an occasional problem, or there is a connector/wiring problem on that circuit that causes the intermittent problem. The ones that aren't always there are the hardest to find.....
projectSHO89
SHOless In St L
I had one a few years back with an intermittent 211 code and drivability issues. Found that the crank bolt was loose and the dampener had backed out enough that the CKP was intermittent...
