I have pulled codes a few times now with the paperclip method, but I occsionally pull code#13.
According to Midwest SHO:
13 - ISC did not respond properly (extends to touch throttle then retracts for KOEO) Idle Speed Control motor or Air Bypass not controlling idle properly (generally idle too high) ISC sticking open ITS circuit or TP sticking"
Should I worry about this? What does it mean? I don't ALWAYS pull it, but I do always pull #11, which is all systems check fine. I don't really understand the automatically adjusting idle, so any help is greatly appreciated.
Also, what the **** is "GOOSING" the throttle? huh I can never do that test right.
