clutch problems or trans?
Sho Amo
SmkTyresntDrugs
Olney, Md
The other night i wound it up thru 3 gears and when i went into fourth at about 100 my gears grinded or somethin now it doesnt go into gear good at all. Someone said synchros and my dad says clutch and TOB.
Any help is wanted. Thanks
1993MTXSHO
Its a Taurus...
Jersey
my money is on the clutch and TOB, I had this happen one time after burnign out throuygh 4 gears and I ground 5th adn then it wouldnt go in any more. I let the car cool off and it then drove OK, but I got my clutch and TOB changed adn all was well. BTW that burnout on the wet road was before I knew abotu SHOBOOM, id never do that now:thumb:
EMB2580
Mike is a L O S E R
Zion, Il
occasional rough shifts
Sometimes mine doesn't to go into gears smoothly, usually, it is a lot easier when the car isn't moving, what could that be? My motor mounts are getting bad, could that affect shifting?
Edit: Just out of curiosity, "SHOBOOM" means blown diff pin?
EMB2580
Mike is a L O S E R
Zion, Il
I did a search and answered my own question:doh:Uupdate on my hard shifting...seems that 1 to 2nd is the funkiest, doesn't do it all the time, stupid question: could I not be pushing the clutch pedal far enough?
Sho Amo
SmkTyresntDrugs
Olney, Md
im thinking i stretched my clutch cable. I tryed to adjust it today and theres nowhere to make an adjustment. My friend has a 99 cobra and he knows they can be addjusted but he cant find it anywhere.
EMB2580
Mike is a L O S E R
Zion, Il
I heard somewhere, can't remember wherethough , but if you pull the pedal up with your hand till it clicks then press it to the floor that should tighten it.
