Clutch Pedal Play
Xs SHO 1
Unknown
McHenry, Illinois
do all MTX SHOs has the same clutch pedal play? does the clutch engage 1/4 way out? 1/2 way out? or do all MTX SHOs clutch engage differently?
i know most cars with a clutch engages at different heights.
thanks
<small>[ February 23, 2004, 05:01 PM: Message edited by: Xs SHO 1 ]</small>
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
ive driven 5 different mtx SHOs now.
The clutched engaged and dissengaged at different heights from the floor.
I would attribute it to wear on the disc, but even my '89, with a fresh clutch engages quite high
EXP1787
IN
My clutch pedal has little to no play. Its almost as if there has been a stiffer aftermarket clutch installed. The former owner told me that it was replaced about 6k miles ago by the owner before him. Any local guys want to drive it and let me know if it feels right? shrug
masho95
got Zex?
Chicopee, MA
When I first had my 9-puck fibertuff clutch installed I "thought" is was engaging in the middle. The more I drove it I started to notice it was engaging almost at the top of the release. Only a few thousand on the clutch.
autobahnsho
SHO Victim
NY for now, WY for real
I put a new clutch and cable in, it engages EXACTLY like it did with the originals.
It's engaging around 3/4 of the way after I'm releasing. I guess my auto-tensioner works.
The pedal feels solid the entire way.
EXP1787- What do you mean by no play?
If it's not engaging where you want it to, you can adjust it. Just be ready for some frustration...
David Carpenter
