clutch adjustment??
Dylan
Central NY
Is their a way to adjust the clutch pedal??
Im thinking the pedal in this car is getting low. As it takes more pedal to work the clutch. But once its in gear it grabs just fine, even under good power. So im thinking and HOPING its just the pedal getting low, and not the clutch getting low.
Thanx for any help or info with this :salute:
Ishodu
If all the parts in the clutch pedal are working good all you need to do is lift up on the pedal and it will adjust the cable tension. Do this a few times. If you hear a click it did adjust.
