Clutch adjustment ?
SHOCarGo
SHOCarGO
Utah
does any one know how to do a Clutch adjustment on an 1992 SHO... well when i sift into 5th or rev it grinds and i was told it needs adjustment can someone help me out
shospeed143
Onalaska, WI
just pull up on the pedal and then just push it to the floor you should hear a few clicks if it is out of adjustment.
sho'noffmtx
Many SHO's
Delano,MN
if that doesnt work try changing the fluid. my pontiac used to grind when going into 5th until i changed the fluid. now it doesnt grind anymore...
its only 3 qts and could probably stand to be changed anyway if you dont have any reason to believe its been done recently.
SHOCarGo
SHOCarGO
Utah
when i pull up on it and push down doesn't make any noise and i cant fill anything. i will change the fluid and let you know..
moobypets
mooby
quebec
ok so you did th epull thing and does it still make noise
if so it either oil wich i doubt
or bad beering or pressure plate
ultimatesho
Fort Bragg, NC
reverse will always grind enless you put it into another gear first, preferably 3rd.....reverse is not synchronized in our trannys
moobypets
mooby
quebec
nope im all french and even my french suck and thank you skinney i was sure i was typing this correctly
but yeah im a frenchies
