Clunking from transaxle while turning?
munkee
Too busy...
Missoula, MT
The two that I have done ran about 85 dollars at napa for the bearing and a new hub. Just the bearing was about 40 bucks. A press is nice but you can do it with a hammer and punches too. Just a word of caution, it is a pretty difficult pita job to do, especially without the proper tools. Also, it isn't something you can get in the middle of and then decide to have a shop do, I know I have been there. Some things are worth spending a little cash on. Good luck.
rangerj
Brunswick, Ohio
Gentlemen,
1.) Beginning in 1994 (maybe 93) the front wheel bearing and hub is a unit, and is bolted on. Simple nuts and bolts for replacement. The unit is expensive, but much easier to change bearings than the earlier SHOs.
2. Pekin212 - The outer CV joint can be removed without pulling the axel. If your boot has not been ripped for a long time, you may be able to replace the grease and the boot. Is there any grease left in the joint? Has it started making noise? If you have doubts about the joint, get a fresh joint from raxels.
With the car on the ground, remove the axel nut. It is a "lock" nut and will be replaced, NOT REUSED. Jack the car up and put it on jack stands. Remove the wheel, brake caliper, and disk. Remove the ("pinch-pin") nut and bolt that "pinch" the ball joint stud to the steering knuckle.
Remove the tie-rod end from the steering knuckle. Plan on replacing the nut on the pinch bolt, the tie-rod end, and the cotter pin as a safety proceedure (cheap insurance).
You can use a pry bar to force the lower control arm down, so that the ball joint stud clears the steering knuckle, or use a small "bottle jack" to push against the inner fender well lip and push down the lower control arm (protect with piece of wood).
Once the strut and lower control arm are free of the ball joint, and tie rod end, push in on the axel. You can pull out on the strut at the same time. You do NOT want to pull the axel out of the trans. It helps to have an extra pair of hands hold in on the axel. The inner joint is spring loaded, and can be pushed in a few inches.
Once you have the strut and steering knuckle clear of the axel, you can remove the torn boot and the straps that hold the boot on.
Now, have that extra pair of hands hold the axel straight, and in the trans, while you hit the outer CV joint with a hammer. Use a piece of wood to protect the joint. The object is to drive the joint off of the axel.
There is a "circlip' that the CV joint has to "pop" over. It will take a good sharp, straight, rap of the hammer to make this happen.
If you are going to re-use the CV joint, clean it with a cleaner that will not leave a residue, such as Gum-Out. Blow it dry with compressed air, or let dry by evaporation. Once it is dry, pack the joint with 25% to 33% of the grease that comes with the boot.
Put the small end of the boot on the axel and apply the boot clamp. There is a "tool" you will need to "crimp" the clamp to tighten it. Now fill the boot with the remaining grease.
If a new "circlip" is supplied with the boot (usually the case), put it on the axel now. Pop on the CV joint. You may need to "tap" it on with the aforementioned hammer!
Apply the large boot clamp and crimp it tight with the "tool".
Reassemble the rest in the reverse order of disassembly, and your done. Use your shop manual for the torque references. The axel nut and the nut on the pinch bolt are recommended to be replaced.
If you do not have a torque wrench that goes high enough in torque for the axel nut, I think Auto Zone will lend you one. If not, stop at a local garage and have the mechanic do it for a small fee. I just did this on a 92 Sable a few week ago. It can be done. rangerj
pjtoledo
'ol man in the SHO
toledo,ohio,usa
Minor correction, My 95 SHO MTX has the same style front bearing/hub as 89 thru 94.
The point I was trying to make is the front bearings can seperate if something does not clamp the inner races together. Don't take the axles out then push the car around.
Perry Toledo,Ohio
Perry Toledo,Ohio
rangerj
Brunswick, Ohio
Perry,
You are right, I should have checked my references. I did a front brake upgrade to 96 standards and remembered having to get hub and bearing assemblies. Thanks for the correction.
thumbs_u rangerj
crizzaSHO
Norwalk, CT
Well guys thanks for all of the input. crazysho's dad actually determined, along with Corey(crazysho) and this stallion transmision man that the transmision has to be opened up to fix the problem. The Quaife has been ordered...
ShowMe
Keene, New Hampshire
The clunking noise could be coming from a bushing moving in and out of place as your turning. Sometimes they can be hard to pinpoint unless you have a thing called a chassis ear. It has about six outputs that you place on varios spots you think the noise is coming from and as you drive and get the noise to happen you go from one channel to annother untill you hear the loudest click in the earphones. It has been a very usefull tool for my diagnostics and has saved me alot of time and money doing the guess work. I got mine from a Mac Tools distributer, but Snap-on or any other big tool distributer should have one or can get one
