Cheesehead
For whatever reason my clock won't update when you select GPS time. It also won't stay updated when I manually change it. The only time it's correct is when it connected to my IPhone. Any suggestions?
Taken the dash apart, maybe a stereo upgrade, just trying to clear up you haven't made changes and pulled the GPS cable out of the APIM, and you already based on the year have Sync3.clock won't update when you select GPS time
Yeah I haven't touched anything. I wonder if I need to repurchase satellite radio? I even did the factory reset option in settings. Didn't work. Not a huge deal but you get where I am coming from. Suri reading text is on the fritz as well, and only my work Iphone connect to Sync3 though my personal Iphone is older but works great otherwise!Taken the dash apart, maybe a stereo upgrade, just trying to clear up you haven't made changes and pulled the GPS cable out of the APIM, and you already based on the year have Sync3.
Nope - bad GPS antenna - is my guess - and a guess.I wonder if I need to repurchase satellite radio?
My battery is old! Was told to replace it so that could be itMan, you might have the APIM going bad. Oh, and how old is your battery?
