ACOK
When depressed about 80% of the brake pedal, there is CLICK noise from that area, then when release the pedal to the same position, same CLICK noise again. Once at this same location and only once every whole depress and whole release.
Before this, I empty the brake fluid reservior to replace the cruise control disconnect unit under the M/C. Air into the brake system?
Could air in the brake system cause the CLICK noise or other reason?
Thanks
Thanks
