check oil light
nothingtoseehere
My check oil light came on earlier, pulled over turned off car, let it cool a few minutes and checked the oil, it was fine. Light was not on when I restarted. Was this just a 'fluke' in my electrical or what...
-RANDY-
S
SHO bulley
Guest
Probably, maybe it doesnt like the taste of the oil your putting in. Min gets ****** if i feedit anything but castrol, it gets crankey..
nothingtoseehere
It has gotten Mobil Synthetic ever since I bought it. It gets Mobil everything pretty much, Mobil Synthetic oil, tranny fluid, SUPER gas (97 octane). Just scared the shit out of me because I just put $1,000.00 into her.
The CHECK OIL light is connected to the oil level sender in the oil pan and illuminates when the oil level is low. The OIL light with the oil can image is connected to the oil pressure sender and illuminates when the oil pressure is below the safe operating pressure. The operating manual states that you should not operate the engine with this light illuminated - engine damage will occur.
Scott
1991, 252K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/polyurethane, SHO Shop front & rear strut braces,
Class II hitch, Silver award at the SHOklahoma Car Show
nothingtoseehere
It was the CHECK OIL light on the right side of the cluster. Was only on for a moment before I pulled over and shut it off. It has not come back on since and the oil level is fine. Checked it this morning, on my lunch break and when I got home form work.
-RANDY-
Mike Stitzer
PA
My oil pressure light will flicker anytime I lug it while starting out and the revs drop to about 500 rpm. I consider this normal though, as the engine is barely turning so naturally the pressure will be low for this split second.
Mike
DavidBGano
Monroe, MI, USA
If it is just the yellow check oil light, I would not worry too much... that is simply telling you that the monitor believes you are about 1 qt. shy of full on the oil.
I almost sh*t myself the first time mine came on, which made me dart from the left lane to the berm in 5 seconds flat... then after reading the manual I found that it is only the RED light that you need to WORRY about. The yellow is more of a courtesy light than anything. And if you burn any oil between changes, it can go off easily.
Hope this helps.
Mike
David Gano
94 SHO ATX
1000 watts Kicker Amps
2 10" Kicker Solobarics
JL XR Component Speakers
Clarion Head & DSP Unit
