check engine light in a 95 sho
bessadok26
west palm beach
i have a 1995 3.2 sho with 111ks miles on it (52k highway miles) i had the fuel pump changed,new alternator,new computer,new fuel relay fix the ac but the check engine light keeps coming out.i live in west palm beach florida and arround here i cant find someone who understands the car,and who can fix it,every mecanic i take it too cant figure out whats wrong with it.if there is someone out there who can help me find a mechanic who knows the specification of the car otherwise im gonna end up selling the car which is my last resort .please help me
djcannon
Ohio
It's probably just an O2 sensor. Heck, you've replaced all the expensive stuff already, so don't give up yet!
The 02 sensors are cheap. May as well give those a shot before selling it. Replace them both. I'll bet your CE light goes away.
To be sure, I'd check the codes, or have a Ford technician do it for you, though it doesn't sound as though you have a competent one around. But I'd almost guarantee it's the O2's. They fail frequently and are probably the #1 cause for a CE light.
Good luck.
EMB2580
Mike is a L O S E R
Zion, Il
MY CEL came on again tonight, I'm thinking it's the O2'(s) as well, it'll come on for a few minutes and then go out, the car runs exactly the same (great) when the light's on.
Edit: Bessadok26, mine came form WPB too, cool!
doclees
Harrisburg pa
Check codes first! Use this forum and search or ask. Unless you have a ford mech that has a SHO save your money. 111k miles it is almost broken in. Tell us more on how the light is coming on. Many little things cause CEL that don't need action now. If the CEL doesn't make it run bad don't panic. Some real smart and seasoned folks on this forum.
thecrew2999
3.2 MTX SHO
Harrisburg/WilliamsportPA
hes right there is some extremely smart people here who will know anything you will probley ever need to know about these engines.
if you go to sell the car let me know :naughty: i love these cars.
rangerj
Brunswick, Ohio
Many, if not all, Auto Zone parts stores will read your codes for free.
Call your local auto Zone and see if they will do this for you if you do not know how. The check engine light is triggered when the computer does not get the signal it is programmed to expect from one or more sensors. A sensor may have failed or there may be a poor connection or a grounded or shorted wire from the sensor to the computer. As Steve says, check your codes and they will give us a clue as to what is triggering the CEL.
And whatever you do, DON'T let the idiots at AutoZone try to diagnose it for you. 98% of them don't have the experience or training to do so. Are you feeling lucky that you might have gotten a member of the 2% remaining?
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
A couple of months ago, when my CE intermittenly came on, I went to 4 autozone's to have my codes pulled. All of which declined the ability to pull them because they could only pull codes for OBD-II cars. Idiots.
Back on topic, as stated above, pull your codes. All you need is a paper clip, and it can be done using the procedure at this site. . . http://www.shophoenixproject.com/eec/eec.htm
sho_me92
it`s SHO time
utah
if your car has a EGR i would check that and clean it.. my dads atx turned the ce light on sometimes but i cleaned it out and never came back on
