Cheap Injector Upgrades
Irish Pride
Irish Inside
MusicCityUSA
This is a list of cheap injectors that can be used as upgrades for the SHO. These are drop in replacements for the stock units and can be found on Ebay readily available. I made this list when I was upgrading my SC car. In the end I ended up buying Injector Dynamics ID1050s just because I will eventually go E85, but if I ever need to replace the injectors in the Blue 3.4 this is the route that I will go.
Boost
550cc/52lbs hr 12.5 Ohms High Impedance
440cc/42lbs hr 12.5 Ohms High Impedance
NA Built/High Compression
370cc/36lbs hr 12.5 Ohms High Impedance
91-99 Dodge Stealth turbo
91-99 3000 GT VR4 turbo
92-96 Mitsubishi Diamante
87-03 Mitsubishi Galant VR4 turbo
86-92 Toyota Supra turbo
All RB20, RB24, RB25DET, RB26DETT, and 7MGTE with top feed fuel rails.
-Chad
bigro007
Boost
-Chad
Hi My name is Andre I'm looking to replace my injector on my 1990 sho which one would you recommend thank second question I have 2 sho one at 60 mph run at 2400 rpm the second run at 2800 rpm same speed where they 2 tranny gear ratio available? Thank
Joe_SHO
ND
If you are not doing anything crazy with the engine, you are best off with oem injectors. If you cannot tune the ecm, you are pretty much stuck with oem injectors. No worries because oem injectors work great.
zak
east of Hartford
Injectors off a 3.2 liter auto trans SHO flow just a bit more but should be within the 1990 ECMs ability to adjust. 14.2 vs 13.7 something like that.
