Charging problem
ManicMike
Speed Freak
Bear, DE
Well, my SHO has developed a charging problem. The battery keeps being drained, 2/26 i'll go see it and use a muti meter and see if the alt craped out on me. If it hasn't, i'm lost. So any help would be great guys. :)
With the engine idling, you should measure at least 13.5V at the batteries terminals. Less, and the alternator is not generating the required voltage or current to charge the battery.
Check out AutoZone and O'Reilly for a starting place for remanufactured alternators. You should be able to find one with a lifetime warranty for a reasonable price. The removal/replacement is not a tough job. Check out the repair guide section of the AutoZone site for the procedure.
ManicMike
Speed Freak
Bear, DE
VICTORY_LAP FDA-03 $39.99
65, 75, 80 AMP ALTERNATOR (WITH INTERNAL REGULATOR) EXCEPT 3G ALTERNATOR.
Thats pretty cheap...lol, so the install/removal isn't hard? Like time wise, how long you think it would take, from first bolt to finishing connections?
SonicRiot
Handbanana!
CT
That's a dirt cheap alternator. Buyer beware.
A couple of things to keep in mind: The higher the amperage output, the higher the resistance. The cheaper the brand, the worse the brushes, and the higher the resistance.
The higher the resistance, the bigger the power drain from the engine.
Oh yeah, and cheap alternators break prematurely, just like cheap starters. No two ways around it.
Good luck.
P.S. If you want a good upgrade, call Powermaster. Expensive, but reliable and powerful. They will tell you if they have a model to fit. Then call Summit for the discount price.
ManicMike
Speed Freak
Bear, DE
DURALAST-IMPORT 90 AMP 14497 LLT $129.99 Or is this the right one? I'm hoping its the cheaper one.. but i think its the duralast one. :doh:
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
Im unsure of the part numbers. maybe search the forum for the proper number. Im too used to the '89 SHO alternators, they are specific to the '89.
Anyhow, an alternator swap can be done in a matter of minutes. I recently swapped mine out with a working used unit in ness than 20 minutes.
Unplug battery, disconnect electrical connections on the alternator, loosen the idler pulley nut (14mm), then loosen the belt tensioner (large allen head screw), remove belt, then remove alternator.
Assemble in reverse!
The hardest part is removing the lower alternator mounting bolt. The AC equipment gets in the way a bit.
Rob94
Northbridge MA
First off, you need a 130 amp alternator. Autozone has the Duralast brand listed at $159.99. If you do need an alternator, it is usually cheaper to have yours rebuilt.
SonicRiot
Handbanana!
CT
I don't think anyone sells rebuild kits for them, though it would be very nice an cost effective for those of us who know how or are willing to try.
Rob94
Northbridge MA
You can find in the yellow pages rebuild shops. I pay $80 with a one day turnaround to have mine rebuilt all the time. It's just bearings and brushes.
Rob94
Northbridge MA
I have it rebuilt "all the time" as in I've owned it for nearly 9 yrs and put 195,000 miles on it. I also do side work for various friends and family, and have had their alts rebuilt. Always cheaper than buying new/rebuilt.
Bizzy
I'd also go the local shop rebuild route. I took my alt in there after I dropped it while putting my UDP's on. They rebuilt it with a new voltage regulator, new shaft, and new bearings for $54 with tax.
Never again will I buy a starter or alternator from an auto parts place.
ManicMike
Speed Freak
Bear, DE
Just so i know, whats the Volts in needs to put out? and one more thing, how many amps per volt?
SonicRiot
Handbanana!
CT
The draw with the car off should be less than 4 millivolts. About 2 is fine. 4 is high.
While running, the alternator should put out between 13.5-14.5 volts. Any higher and the battery may gas. Any lower and the car may run poorly while under load from many accessories (the more acessories loaded, the less the voltage will be at idle at the battery).
The amperage will vary upon loading the battery. It will only put out max amperage (90, 100, 120, whatever you have) when the regulator is bypassed and the alternator is full-fielded. While full fielding, reduce the amperage to the battery by turning on all accessroies.
ManicMike
Speed Freak
Bear, DE
So just check the batt. terminals for 13.5 to 14.5 Volts. IF it don't read in between those numbers, its definally the alternator?
Thanks,
Mike
SonicRiot
Handbanana!
CT
no...
Not definately.
That's why you need to full field the alternator and check for missing voltage or unwanted voltage at various places in the alternator. I have to run for now, but I'll write up the procedure later. It requires a multimeter.
ManicMike
Speed Freak
Bear, DE
SonicRiot said:
no...
Not definately.
That would be great. Yea, like tommorow i'm going to pick up a 42-range Multimeter.
bmytych
