SHOstuff
Is there a write up on how to change the fluid for the ps? My ps pump all of a sudden just start having a whining sound to it which is annoying.
Just flushed mine.
Grab a 3/8th clear tube about 6 foot.
Grab a gallon or two of Type F ATF. I used Castrol. Also get some Lucas PS fluid.
Get a 3/8th double barb fitting I used plastic.
Pull the small return line from ps resevoir and have a plastic cup underneath to catch the run off. Then place a a few inches of tube there to keep it from leaking out and clamp it. I used vice grips. Now hook up the rest of the tubing to the double barb and the return line.
Use a funnel to pour the ATF into the resevoir. You'll need a friend to start the car and turn the steering wheel back and forth while you fill the reservoir. Be careful it goes quick. Once the fluid begins to turn red and not some nasty black color, shut the car off.
Hook all back up and fill with the rest of the ATF but leave room in the reservoir for about 12oz of the Lucas PS fluid. This will help with the whine and give you some time before replacing the ps pump. Good luck and be carefull. I'm not responsible for your F up.
Is type F trans fluid the same as PS fluid? I have hears of running ATF fluid in your gas tank to help remove build up, and I think someone recommended usinf a quart in your old for a short interval before an oil change. Seems like pretty handy stuff.
No it is not. The SHO uses atf in the ps system NOT power steering fluid.
Just flushed mine.
I made the same mistake for a while , I flushed it just like others have said and been running great ever since![]()
you can us ps or atf
but you need to drain the line completely if not it will not be clean
and youre supposed to stop just before the end off the curve before the lock
and you need to be fast lol to turn the wheel and to fill the reservoir too
