CEL
Fletch
Orlando
When I start my SHO up the check engine light comes on and stays on no flashing...wtf??
The CHECK ENGINE light is your friend and is trying to tell you what is wrong with your engine control system. Follow the links at the bottom of my signature to learn how to do the simple key on engine off (KOEO) and key on engine running (KEOR) tests. You will need to run the KOEO test to retrieve the error code(s) that was set into the memory section when the light illuminated. It is simple to run the test once you have figured it out and it is a great tool to help keep your engine running at its best. I have posted more details on this process just recently. If the links aren't enough information, you may want to try the search function at the top right of the Forum's pages.
