cd player
me6894
Canton, Ohio
ok im aware i cant put a cd player where the radio is now, but ive heard you can put it in the glove compartment, so my question is is there a wiring kit i can buy to make it easy? what all do i need to do?
thanks
NebraskaSHO
Harumph!
Omaha
You can put it in the ashtray without much work. All that needs to be run is Power, ground, speaker wires, 2 rca's, and an antenna extension to the trunk. From there I just spliced everything into the factory wiring and said good bye to the football's radio.
There may be a kit that will just splice into the factory wiring in the trunk, but I was unaware of it when I did mine in the fall of 05.
nice car BTW :thumb:
66goat
stafford sp, ct
Best buy did have dash kits at one time replaced the whole "football" shaped panel as Paul called it. I am sure it was for a Taurus, that shape is pretty much unique to the Taurus.
Those were for non-electronic climate control units. All SHO's have the ECC units. The regular taurus had adjustable manual dials which the kit was built to replace.
thanks
There is a Metra wiring kit. I haven't installed my aftermarket headunit yet, but I think the kit # is 70-5715
me6894
Canton, Ohio
you mean it literally sat in the ashtray? what did you use to hold it in? do you have any pics?
oh and thanks, your car is pretty nice too:)
NebraskaSHO
Harumph!
Omaha
Right where the ash tray used to flip down. It's very sturdy once it's down in the actual location. I've only had to remove it once since it was installed, which was about a year ago.
NikonPhotos003
All I did was cut out the opening for the cage housing, and install it.
me6894
Canton, Ohio
ehh i dunno if i wanna tear my interior apart... do you think it would work in the glove compartmen? even if its sitting vertical while its closed? it looks good on your car BTW
me6894
Canton, Ohio
another thing, the last car the cd player was in there were 4 speakers, the SHO has 6 so how do i get them all to work?
NebraskaSHO
Harumph!
Omaha
It has 6 speakers, but only the front speakers are split, so some of the hi's go to the tweeters and the lo's to the "mach" mid ranges...
So yes, my eclipse 20* x 4 to the factory wiring works just fine. And for vertical in the glove compartment? I did that with my console before I did it with my ash tray.
Another linky:
Console 5
And after that:
Eclipseradio
Trust me, the ash tray is by far easier than either of those...
EDIT: and I'll tell you why. First, the radio is in an ideal position if you rest your hand on the shifter to change songs/stations/etc, second, the console was only cool if stopped, the football never completely functioned, and fourth the radio is well hidden down in front of the shifter, and below the factory stereo.
Something like this, with the shifter in P
Eclipsemounted
me6894
Canton, Ohio
ok i figured they were split, so how exactly would i wire that? BTW the one where its actually where the radio goes looks really good, did you have to fiberglass that in?
NebraskaSHO
Harumph!
Omaha
I used bondo, no fiberglass. Looking back on it some glass would have been good to reinforce it in the back, but I didn't get the EATC to function so it was scrapped.
I drove around for over a month and a half with the defrost on hi heat and hi fan. :frown: At least it was in the winter...
I ran wires down the passenger side and through the trunk, and unplugged the factory amp, and cut the harness and wired in LF, RF, LR, RR from the Eclipse into this:
http://www.v8sho.com/SHO/SpeakerWiringColorCoding.htm
Like I said, if their was a bypass kit I was unaware at the time and had to cut the factory wiring harness in the trunk as to hook up my HU to the factory speakers. Not that big of deal if you leave enough to wire resplice the connector back to the wiring. If need be. My connector has about 2" of wire left on it.
me6894
Canton, Ohio
ok lemme make sure i have this right before i tear into it. The wiring harness that goes to the trunk, can you splice into that once you pull the factory radio out? oh and can i use a coat hanger to get the stock radio out? im not used to fords but dont you just stick it in the 4 holes and itll pop out?
NebraskaSHO
Harumph!
Omaha
The radio removal tools are a couple bucks, at most.
I cut the factory harness/connector off and spliced all of my wires into that. After I ran them from the cab back.
Rubix
radio removal tool = $4 at walmart... or you could just use a coat hanger or two, or small screw drivers
NebraskaSHO
Harumph!
Omaha
Yep thats where I got my tools. The radio is still a pain to get out though with those things... at least it was for me.
me6894
Canton, Ohio
ok so you do actually have to run the wires back from the trunk? im kinda slow tonight lol is there a place in back to the radio you can cut the harness that runs to the trunk so you actually dont need to go to the trunk? i just wanna run it to my glovebox right beside it
NebraskaSHO
Harumph!
Omaha
Uh, I dunno. The amp in the trunk has the speaker wires running out of it, and also has two other connectors. One for power and the other for the CD changer, I believe.
I sold the factory amp over a year ago.
me6894
Canton, Ohio
i didnt know there was an amp in the trunk, i guess ill just have to take a look at it
NebraskaSHO
Harumph!
Omaha
Yep, thats where the "radio" sends its signal and the amp outputs that to the speakers. Basically.
Drivers side, behind the wheel well, in front of the changer.
Looks like this:
TaurusAmpclose
TaurusAmp
And no that's not an RCA out, it's for the antenna.
