frcoonhounds
I have a 93 atx.
The car has been having starting issues that I believe are stemming from the camshaft position sensor. However, yesterday the car was running as usual, and as I went to start it at the gas station all power was gone. A loose neg battery cable seemed to be the culprit.
After reconnecting the cable, SHO wouldn't start. Since looking at it today, the first time i turned the ignition to ON I had no sound from the fuel pump. Decided I'd check the fuses again and disconnected the battery. After finding no blown fuses I decided to pull some codes and reconnected the battery. When I turned the car to ON the fuel pump sounded, but SHO wouldn't start.
When I turn the car ON the ccrm does click, but no fuel pump sound. Also, when I have the code scanner connected (has new battery) it has power. After turning the ignition to ON, the code scanner does not receive power. Basically, can't perform the engine off code test.
Sorry for the novel, any help is appreciated.
