CCRM replacement
dmjarosz
Proud SHO owner
Hamburg, NY (S. of B'lo)
So I came home today, and my cooling fans wouldnt shut off when I turned the car off. From reading here it seems as though the CCRM is bad. I also read that the CCRM was discontinued in '98. Since I have a '99, wat piece do I need to replace? It looks like its going to be some relay in that box next to the battery but I dont even know where to start looking...
NebraskaSHO
Harumph!
Omaha
Don't know. If I would have removed that relay when I installed my SCT tune I could tell you. But since I didn't, I'm not sure.
Although I would like to know as well.
Silvapain
Limestone, IL
The CCRM is mounted to the battery box on the fender side. Take a look and see if you have one - I'm almost positive you do. I believe it may have been updated in 98, no discontinued.
