If you need one I have them and test before shipmentOh what issues am I not having lol. Car is 28 years old and cranky lol. It’s having a hard time starting and it is throwing a ccrm check engine code. I just wanted to see if it controlled the fuel pump so I can try and replace that before I drop a fuel tank.
Thank you so much for the help!!!!
The CCRM controls the fuel pump, cooling fan, and AC compressor.
What issue are you having?
Can you hear the fuel pump priming when you turn the Ignition to the On position?
Thank you for the help. I got one from the part store and the fuel pump continues to stay on when vehicle is sitting. Only turns off when you turn to runIf you hear the fuel pump prime the rails when the ignition is turned on, it's working fine.
Let us know all the codes you got. Note that code 542 Fuel Pump Secondary Circuit Failure can be caused by simply stalling the car at a light.
A '92 MTX would require an 'M' code CCRM.
543 172 157Can you advise what code numbers came up
How much do you charge for a m code ccrm??If you need one I have them and test before shipment
$80How much do you charge for a m code ccrm??
Do you still have a ccrm?If you need one I have them and test before shipment
I do, although the price has increases significantly.Do you still have a ccrm?
