CCRM help
Laurel
Utah
I have a 92 Taurus sho MTX it has a code for a ccrm constant control relay module. Does anyone know if this houses the relay for the fuel pump? Thank you
Laurel
Utah
Oh what issues am I not having lol. Car is 28 years old and cranky lol. It’s having a hard time starting and it is throwing a ccrm check engine code. I just wanted to see if it controlled the fuel pump so I can try and replace that before I drop a fuel tank.
Thank you so much for the help!!!!
Irish Pride
Irish Inside
MusicCityUSA
Can you hear the fuel pump priming when you turn the Ignition to the On position?
thegreatbriguy
Carlisle
If you need one I have them and test before shipment
If you need to replace the CCRM you have to get the model with the same letter on the top of the module.
BaySHO Performance
SF South Bay
If you hear the fuel pump prime the rails when the ignition is turned on, it's working fine.
Let us know all the codes you got. Note that code 542 Fuel Pump Secondary Circuit Failure can be caused by simply stalling the car at a light.
A '92 MTX would require an 'M' code CCRM.
Laurel
Utah
Thank you for the help. I got one from the part store and the fuel pump continues to stay on when vehicle is sitting. Only turns off when you turn to run
I agree. the MAF error will easily cause an oxygen sensor code. Even if cleaning the filament does not cure it, it still could be faulty. I would look for a good used oem one. Contact Dan Barbush SV&HOdan on this forum. You can send him a message through the 'start a conversation' feature of the forum.
Irish Pride
Irish Inside
MusicCityUSA
Is the car running rough or are you just chasing the check engine light right now?
You could try unplugging the MAF and seeing if that makes a difference for the time being.
