matt621 said:.....
So, that would indicate the fuel pump died, correct?
No. This just confirms the relay coil is working and the clicking you hear is the contacts being pulled in. You do not know if the relay is passing power. The easiest way to check is to again ground the test pin with the key on and with the relay pulled in there should be 12V at the inertia switch in the trunk. If it has and is passing 12V then the fuel pump or the "in the tank" wiring is suspect.
